central - east central Minnesota - | If it's not going to be attached to the house, you could simply "float" it on the ground. Setting out a couple patio blocks to set treated material on. Another option is to "treat" the material with foundation coating. It drys solid and repels moisture and decay. If I were to consider a post, I'd get Douglas Fur and treat it myself. Water proofing sovent then after it drys, I'd use foundation coating on the part underground and up a few inches above. Then use some of the butal tape (used for window flashing) and secure that to the portion underground and slightly above the ground level. The other consideration is to pour a floating slab. As long as the slab is below the rim of the house, so no water could get under siding and agaist the house wall . . . . Concrete slab could be less money . . I recently dug footings, set 5 courses of block (stem wall) and poured a 6 inch concrete cap with 2 steps up for my entry - cheaper then a wood / composit material deck of the same design. My deck / porch will be maintinance free for ever . . . . I reroded it also. Its strong enough that the backhoe/excavator can sit on it to dig out the basement, if the house ever burned . . . . . |
