Search Forums | Classifieds (95) | Skins | Language
Stine seed's Fieldmax harvesting system
Brandon SWIA
Posted 8/31/2007 14:15 (#196304)
Subject: Stine seed's Fieldmax harvesting system
Anyone have pictures of Stine's seed corn harvester? I ran across it on their website and it looks neat. Just was wanting a better look.
Brandon
AGCOfan
Posted 8/31/2007 18:54 (#196380 - in reply to #196304)
Subject: RE: This?
S.W. Manitoba
This looks like it. Impressive. There's a seed company up here with something similar and its even got air conditioning.
Take care,
Nathan
Edited by AGCOfan 8/31/2007 18:57
(Seed corn harvester (750 x 450).jpg)
(Seed corn harvester#2 (750 x 450).jpg)
(Seed corn harvester#3 (750 x 450).jpg)
Attachments Seed corn harvester (750 x 450).jpg (99KB - 181 downloads)
Attachments Seed corn harvester#2 (750 x 450).jpg (97KB - 152 downloads)
Attachments Seed corn harvester#3 (750 x 450).jpg (81KB - 140 downloads)
Old Pokey
Posted 8/31/2007 20:36 (#196402 - in reply to #196380)
Subject: What spacing is that corn on?
Sure looks narrow. Is that a common spacing?
BTW, thanks for the pics.
Dan_wcIN
Posted 8/31/2007 22:17 (#196452 - in reply to #196402)
Subject: RE: What spacing is that corn on? Most likely 15" NT
It made a Crop
nt
Edited by Dan_wcIN 8/31/2007 22:18
Old Pokey
Posted 8/31/2007 23:53 (#196502 - in reply to #196452)
Subject: Thanks. Is 15" spaced getting common?
It is amazing to see corn that close and a header that can get all the mechanism together in that cramped space.
Dennis SEND
Posted 9/1/2007 00:07 (#196507 - in reply to #196502)
Subject: Re: Stine seed's Fieldmax harvesting system
I think it maybe 20" rows those divider points look kinda big for 15" and the head itself looks kinda big a lot more than 20' a 16R20 would be 26.6 feet that is kinda what I think it probally is. Dennis SEND
Mlebrun
Posted 9/2/2007 09:07 (#196965 - in reply to #196452)
Subject: 22 inch rows
SW MN and Gold Canyon AZ
Everything Stine plants is on 22 inch rows.
The reason for the field max system is to eliminate excess handling thus giving better cold germs. The corn is elevated into dryer boxes out in the field. The dryer boxes are then put on dryers that slowly dry the corn at lower heat levels and then taken to the sheller. www.stineseed.com
Chopper
Posted 9/2/2007 11:27 (#197031 - in reply to #196965)
Southwest MN
Are you sure it is 22's? I am pretty sure it is 20's, you were probably telling someone how you use Vistive oil in your race car because it makes the car live longer, instead of paying attention to the actual facts that Stine was giving you. Typical DSM.
Chopper
Posted 9/1/2007 20:25 (#196794 - in reply to #196402)
Southwest MN
I believe that it is on 20" spacings, they have 3 - 32 row planters. When the machine is running, I think there are about 12 people riding on the machine, sorting and throwing unhusked ears back through the husker. Sounds like they built another one this year on a 9600 chassis, but offset the cab and moved the motor up front like a 8820. Many thousands of dollars in engineering in that machine.
Old Pokey
Posted 9/2/2007 00:52 (#196910 - in reply to #196794)
Subject: Ok, 20" would make it easier to to make the header.
That's a lot of people and work.
Dan_wcIN
Posted 9/2/2007 22:31 (#197365 - in reply to #196794)
It made a Crop
Might be 20's then. I didn't realize that was a 9600 frame. Thought looked more like a 6620 or 7720.
Pokey here's a site with 15" corn heads.
