AgTalk Home | ||
Top Dressing Corn with urea, what do you use for spreader? Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Forums List -> Crop Talk | Message format |
1770 |
Wondering what you use to top dress your corn with, dry urea. How fancy is your spreader. Any particular good models out there, not talking high clear sp spreaders. Edited by 1770 7/14/2017 05:33 | |||
Patriot81 |
Farmington, Mo | I'd look at BBI. They have a high clearance single axle spreader for in crop apps. I don't have one, but I do own a BBI Liberty and it is a fine spreader! I will own a bigger one someday. Good luck http://www.bbispreaders.com/foundations/store/shopdetail.asp?params... Edited by Patriot81 7/14/2017 05:55 | ||
robmgrig |
West TN | Before I switched to liquid, I used my Newton Crouch variable rate high clearance spreader. Hold about 5 Ton of urea. 60 foot spread | ||
norway |
Eastern Iowa | I have a mobility 600. Works great, 60' spread. I have had my best corn since I started top dressing with this unit. I hate yellow corn. We get urea from terminal and save a lot of $. Dalton Mobility is about the lowest priced high crop spreader out there. | ||
1770 |
robmgrig - 7/14/2017 07:11 Before I switched to liquid, I used my Newton Crouch variable rate high clearance spreader. Hold about 5 Ton of urea. 60 foot spread why did you switch? | |||
BEDFORD |
We use a kvernaland 3point hitch smart spreader, can cover a lot of ground in a short time | |||
beachfarmer |
North Central MN | If we were going to spread our own again I would buy one of these in a heartbeat. Nothing beats the accuracy. (download.jpg) Attachments ---------------- download.jpg (45KB - 64 downloads) | ||
tmrand |
Southeast Colorado | Tires look pretty wide to be side dressing. LOL | ||
robmgrig |
West TN | One year I topdressed with dry urea and got a big thunderstorm shortly afterwards. It floated a lot of urea prills down to the bottom of the terrace. It really showed up bad later in the year. At least with UAN it soaks into the ground | ||
lance81 |
Churdan, IA | These hold 8 ton of urea and drop it under the canopy 80' wide (32 rows). Best side dress method. Never worry about wind. For more info call me at 515-408-2808 Edited by lance81 7/16/2017 10:58 (20170628_112738.jpg) (20170610_105322.jpg) Attachments ---------------- 20170628_112738.jpg (121KB - 55 downloads) 20170610_105322.jpg (127KB - 56 downloads) | ||
cho |
Bet it is not cheap | |||
lance81 |
Churdan, IA | Depends on your definition of cheap...... | ||
cho |
lance81 - 7/18/2017 00:05 Depends on your definition of cheap...... 70k looked on tractorhouse, your a dealer? | |||
lance81 |
Churdan, IA | We are farmers, fertilizer dealer and metal fab shop. Actually the pictured unit would only run around $40k. Have one on auctiontime in a couple a month or so. If you want to see some of our custom machinery visit our website at www.lynxag.com Edited by lance81 7/18/2017 19:11 | ||
(Delete cookies) | |
