AgTalk Home | ||
3208 Cat fuel leak Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
ekeller2 |
So. IL | Have a Cat 3208 that has a puddle of fuel in the valley, is there any common spots where it could be leaking? We looked at all the lines and could not find anything, thinking its from the pump? thanks | ||
Ford&Deere |
Keymar, Maryland | Try tightening the lines? Might not look loose. | ||
Farmin' Fireman |
C KS | Make sure air bleed "T" valve used when changing filters, is closed. Should have a line attached that takes the fuel away when you open it, could be open a little with the line missing. Just a thought. | ||
4WD |
Between Omaha and Des Moines, 7 miles South of I80 | Is everything on "top" that you can see, look dry? (3208 injection pump view with bleed line tubes.jpg) (3208 injection pump side photo.jpg) (3208 injection pump Top photo.jpg) Attachments ---------------- 3208 injection pump view with bleed line tubes.jpg (24KB - 733 downloads) 3208 injection pump side photo.jpg (29KB - 660 downloads) 3208 injection pump Top photo.jpg (37KB - 647 downloads) | ||
4WD |
Between Omaha and Des Moines, 7 miles South of I80 | . (3208 injection pump governor housing view_in paint.jpg) (3208 injection pump side photo_in paint.jpg) Attachments ---------------- 3208 injection pump governor housing view_in paint.jpg (91KB - 768 downloads) 3208 injection pump side photo_in paint.jpg (66KB - 625 downloads) | ||
papadon |
one way to help detect leaks is to thoroughly clean and dry with ether and then spray with a white dry deodorant powder and watch to see where dampness occurs---good luck. | |||
jbstein85 |
western new york | I had a pump come loose from the front cover and leak engine oil. Is it have a turbo on it? | ||
Applicator |
Those engines originally have small drain hoses to keep any fuel that leaks out the valley. If yours are bad or gone, then it might be the injection pump input seal. There are actually two seals and the drain is between them. This keeps the diesel out of the engine (and the engine from turning into scrap) if the inner one leaks. The pump must be removed to fix it. | |||
Alberta Farmer |
West Central Alberta Coldest, wettest edge | I've had the seal on the throttle shaft leak, right into the valley, and very hard to see where it is coming from. It can be changed without removing the pump, just remove the governor housing, it sounds easy on paper. | ||
IdigOhio |
NW Ohio | +1 | ||
(Delete cookies) | |
