Cost to convert seedstar xp 1790 to all precision planting?
baier91
Posted 5/3/2021 20:21 (#8985735)
Subject: Cost to convert seedstar xp 1790 to all precision planting?
Northeast Nebraska
Have 2013 1790 16/31 planter with all factory deere seed star xp advanced monitoring, active pneumatic downforce with hydraulic compressor, 5 load pins: 3 on corn rows 2 on splitter rows, 2 hyd drives, 31 row clutches, pro shaft drives. Planter also has a deere green star rate controller on it that is hooked into the isobus on the planter and it controls a hydraulically driven fertilizer pump/flow meter/valve. What is the cost for harnesses and to control all of it with a precision monitor? Doesn't need to be the newest monitor just needs to work. I have been told that the precision planting Gen 2 monitor will accept a GPS output from an AG leader 6500 running terrastar c no problem. Currently running it on a 2630 but the tractor has AG leader steering in it and the 2630 isn't 100% happy taking the GPS source from the AG leader globe and it's causing issues. https://talk.newagtalk.com/forums/thread-view.asp?tid=994496&mid=897...
Edited by baier91 5/4/2021 08:25
