Case Patriot Autosteer Issue
kunkeljl
Posted 4/8/2021 06:01 (#8939174)
Subject: Case Patriot Autosteer Issue
I have a Patriot 2240 with auto steer. For some reason it won’t disengage when the steering wheel is turned. At first it just did it sometimes and now it’s doing it every time. I can engage auto steer with the pedal and run each line no problem but when I get to the end it won’t disengage unless I push the override switch. Any suggestions?
