ARG going to corn?
Sonlight
Posted 4/7/2021 21:46 (#8938957 - in reply to #8937673)
Subject: RE: ARG going to corn?
Western Ohio; Eastern Indiana
If you spray it now you may possibly need to spray it again if it’s arg and not cereal. It’s plenty early and the art needs time to regrow and get good leaf surface area to take in chemical after being burnt back by winter. It’s possible some plants will regrow if sprayed now. That’s the only problem I see with spraying it now. Give it another 10 days and it will be good to kill.
I’m assuming your arg is similar to here. You may get better snow cover and not have as many leaves that burn back as I do.
