How to connect two computers
turnnpoint
Posted 2/11/2021 07:41 (#8823671 - in reply to #8817297)
Subject: RE: How to connect two computers
Eastern North Carolina
I'll give one more reply in case there is still any interest or need for help. The Windows operating system will also let you setup some simple file and folder sharing between 2 computers if they are networked. And if you are simply browsing the Internet and "the same information" you want on both computers is your browse history and bookmarks/favorites there are web browsers that can be setup to make that information available on the different computers you use. There are also more extensive options that can be implemented on a network like roaming profiles. Pretty much everything you do will follow you among computers if you set that up - but it's normally used more in business and office building situations. If you gave us a little more specific info about your situation and what information you want available on the 2 computers we might be able to give you answers that are more helpful to you.
