vomatoxin
1466i
Posted 11/19/2020 06:46 (#8613560)
Subject: vomatoxin
central Ohio
Those that feed hogs and get this once in a while. Does the blocker work and what level in corn. It are turn in the barrel here testing 8 ppm will the feed additives work. From what Im hearing mine is on the lower side but still tuff on hogs. Need some advice from you hog guys if you be willing to help. Thanks
