Controlling outback steering valve with Trimble display
Boomer24
Posted 6/30/2020 09:44 (#8345022 - in reply to #8343340)
Subject: RE: Controlling outback steering valve with Trimble display
SESD
I don't know about Trimble cabling or how it could connect to the valve. That looks like an EDriveX valve which would be a proportional valve. The connection on the solenoid in the front of the picture is the "enable" solenoid and in the back of the picture are the Left and Right turn solenoids. They're 12 volts to get them to move. The manual override is the trick. Outback uses a couple magnets on the steering column for operator override. Not sure what Trimble would be looking for. There is a load sense hyd line on the valve block where a pressure sensor could be put in but it's not perfect.
