Swapping flow tubes on a magnetic flow meter
Pat H
Posted 11/13/2017 13:35 (#6362544)
Subject: Swapping flow tubes on a magnetic flow meter
Cropsey, IL
I want to go to an 8 inch manure loading set up and I wonder if I can use the same transmitter on a 6-inch or 8-inch flow tube. I've gone through the software a little bit but didn't see anywhere where the diameter was set. Thanks
