Pro700 Input Error Message
torn
Posted 10/6/2017 13:54 (#6291659 - in reply to #6291537)
Subject: RE: Pro700 Input Error Message
roaming
bnobles - 10/6/2017 11:47
I am getting these messages alternating on my Pro700s. I was getting them on 2 of the Magnums and this morning after transferring some lines to my Steiger I'm getting them on it now. When I hit OK on one message the other pops right up. I'm able to hit buttons on the split second in between and use the autoguidance, but it's pretty annoying. Any help?
There are some limits to management items in the Pro 700. How many Growers, Farms, Fields, Tasks, or guidance lines do you have in your display or on the USB stick?
PF-107 just means that your Task filled up and the display created a new one so you can continue logging data. Not a problem unless it's popping up every few acres. You should be able to get about a day's work into a single Task. If your display is creating too many Tasks for some reason, it could be causing the other issue (can't create item because maximum number reached).
Edited by torn 10/6/2017 13:56
