A B lines
WildBuckwheat
Posted 1/24/2023 14:50 (#10057306 - in reply to #10056959)
Subject: RE: A B lines
Middlesex County, Ontario
Pretty basic management:
Once I made an AB line at a heading that I liked, I saved it.
I then moved the line 45' from the edge of the field. That way the line should align with my 90' sprayer and 30' planter without needing to shift.
Then I named the line "Master AB Line." I have each field set up with one "Master AB Line."
If I use a different size implement then I just shift the line to where it needs to be.
