integra
tedbear
Posted 9/22/2022 06:13 (#9855340 - in reply to #9855328)
Subject: RE: integra
Southern Minnesota
Did this ever work with this combine or is this a new install? If it has worked in the past I would suspect a wiring issue. If this is a new install, the cable may not be installed or has damage.
The calibration that we are referring to is a Wizard that guides you through the process of indicating the range of your throat levels. It will have you raise the throat to its highest position and set a value. It will also have you lower the throat to its lowest position and set that value. The system will then display the throat height as a value of 0-100%. You will also select the point within that range where you wish logging to turn ON/OFF. This will likely be different for each head.
