Split seedtube sensor signal
bengps
Posted 3/12/2026 13:22 (#11582459 - in reply to #11582246)
Subject: RE: Split seedtube sensor signal
I dd a split at the seedtube itself with ag leader and 20/20. I had to pull power from only one of the units, and then needed to tee the ground signals from the tube sensor, so I built my own y adapters with 3 pin amp connectors.
The reason i went that route was to compare the population readings between the ag leader and 20/20. I got the same readings within 1% of each other.
