Search Forums | Skins | Language
Exhaust filter
SNB
Posted 12/20/2008 11:57 (#540984 - in reply to #540961)
Subject: Re: Exhaust filter
Sussex Corner, New Brunswick
It is a "particle filter". Its job is to take out "ALL" soot from the exhaust. It also works similar to a catalytic converter, it is suppossed to burn out that soot either using the exhaust temp or it has an injector of its own and will burn fuel to clean itself. If it is plugged you should be able to take the truck back to the dealer and get them to clean it. It is not welded in, it is removable, all dealers are supposed to have the equipment to do the job.
DO NOT UNPLUG. The following link has more info.
http://www.turbodieselregister.com/forums/6-7l-engine-transmissions...
