Search Forums | Classifieds (11) | Skins | Language
Case-IH 7140 fuel bleed down problem
pirlbeck
Posted 12/2/2008 17:23 (#521978)
Subject: Case-IH 7140 fuel bleed down problem
I have a 7140 that the fuel bleeds down when it sits for a little while. After sitting overnight it will not start unless I bleed the injection pump. The fuel transfer/lift pump was changed with no improvement. Any other check valves in the system? Any other things to try?
Thanks!
soybean99
Posted 12/2/2008 17:52 (#522000 - in reply to #521978)
Subject: Re: Case-IH 7140 fuel bleed down problem
fayette county, ohio
my 7120 will do it also unless the fuel tank is full. then is can set and start up anytime. I am guessing a fuel line getting rotten
TLSJR
Posted 12/2/2008 22:02 (#522270 - in reply to #522000)
central Minnesota
Replace filters if you havent done that yet. My 7120 was acting the same.
soybean99
Posted 12/2/2008 22:48 (#522339 - in reply to #522270)
thanks,, can not remember when i done that last time
jedeka
Posted 12/2/2008 22:59 (#522349 - in reply to #522339)
Boone, Iowa
Dont forget to change the small, inline filter at the back left corner of the engine. I always found that the inline filter caused more problems than the spin-on filter.
