| here is a new,,,oops,,,old concept of the same deal. I have an OLD "Thunder Gun". All you need is a common water hose,,,no extra pressure. Then it also plugs in to the roll around portable air compressor. It has as much pressure as most pressure washers with less hassle. No pump to freeze. roll up your hose and put the compressor back in the shed.
Pressure washed a house with it once,,,will NEVER do that again, ever,,but it worked. Would be better if a scraper was fashioned on nozzle so scrape and wash at same time | |
