Near-north Ontario, French River | I run an Ontrac3 with RTK and have no problems staying on the rows . I just looked up a quote I got in the fall to add RTK Ontrac3 to second tractor.. This is with a compass display, so if you wanted additional capabilities you would have to update the monitor... but Compass display, 6500 globe, Ontrac3, all the harnesses , RTK subscription and subscription, foot pedal and some misc odds and ends came it at -+$20k Canadian funds. soo +-15k US? You'd have to check and see if the Compass can do rate controlling or if its just for guidance. I didn't go ahead with it, so haven't looked at things much since then.
edit.. found a second quote, same as above except with Incommand monitor, which is much more capable, +-$25.5k Can
Edited by Thud 3/27/2017 17:25
