| Hi guys.
Rebuilding a power shift and rear end in a 3020. Pulled the finals to do brakes and axle bearings. There is one loose dowel pin on each housing. Can slide it in and out by fingers but no play in the hole. The dowel shows no wear and no sign of the ring gear moving. There is no cracks in the housing as I've had that before. The other two are tight yet.
Anything to be concerned about?
(image.jpeg)
(image.jpeg)
Attachments ---------------- image.jpeg (131KB - 57 downloads) image.jpeg (120KB - 62 downloads)
