Anamoose, ND | I am almost done setting up our airseeder with a Raven Accuflow and a section control kit which will all be run with a Agleader Integra. I want to run 1-1/4" hose from the breakaway at the hitch all the way to the cooler. I am using double 1000 and double 1500 gallon tanks. Tanks have 1" hoses that will be tee'd together then go to a 1-1/4" hose and valve to the breakaway on the airseeder hitch. I see that the Acme threaded fittings come in different sizes like 1-3/4" or 2-1/4" so which size do I need to go with for max flow? Thanks | |
