| I think the 305 mfd only had one steering system, but anyway it turns out I needed to buy a different steering hand pump that has the load sense port on the same face as the PTRL ports. I'll get it thursday, then the simple part will be done after a week of research.
A local CNH tech told me that if the hand pump had the bolt holes I could use it with the accuguide valve (and plug the valve's LS port?). There was a NAT post complaining that it seemed like the hydraulic pump wasn't opening up on their install and I wonder if it had something to do with load sense? Maybe it could be compensated for in the CNH hardware/software, but probably not will the old Leica. | |
