Southeast Iowa | I have been using a wheel magnet for my speed sensor on my sprayer. I have a Cruiser II that I would like to use as speed sensor for my 440..
I think I have the right cable from a supplier. About half way on the cord are two other serial port plugs???? with a 3 pin on one end and a serial port on the other end.
Which port do I use on the back of the Cruiser. It will connect to the 3 pin connector on the 440. 440 is an older unit with no serial port.
What do I have to set or how do I set the 440 to accept the speed from the Cruiser.
I have run for years with the Cruiser II for the light bar and the magnet for speed.
I added flow control to my Blue Jet liquid applicator so I would like to set up for Cruiser speed pickup rather than buying another magnet speed sensor.
Thanks for any help you can give.
Gary | |
