| Hey guys i've got a case 1250 early riser behind a steiger 335 just got them both this winter. Had a problem with low voltage to basically everything on the planter and finally got that fixed ( it was a relay on the backside of the cab right by master battery cutoff). Now my pro 700 is telling me i have high voltage to the PWM output #2 ant that my rate ECU is degraded the codes it's showing are 22023 for the PWM output and 18002 for the ECU. Does anyone have any clue where that is on the tractor?
Any help would be greatly appreciated thanks
