South Georgia | I used SMS to shift around and rename guidance lines.
I also used it to create some guidance "curves". I drew a circle to represent the wetted area under a pivot, then with some help from Ag Leader support, turned parts of the perimeter of the circle into a Curved guidance line so that I could drive a boundary between the wet/dryland. I'm no expert at using SMS, but I thought it worked pretty well. I don't know what you could use that would be better. | |
