Classifieds (22)
Setting up Ubiquiti Nanostations to Connect to Aiport Extreme
Computer Talk
Iowa Quality Hay
1/18/2017 08:16 (#5776002 - in reply to #5775406)
RE: Setting up Ubiquiti Nanostations to Connect to Aiport Extreme
Grabill, Indiana
Thank you for the comments. After reading your instructions I might have set them up incorrectly.
Here is the data from IPCONFIG:
IPv4 Address: 192.168.96.158
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.96.1
I assigned static IP addresses for the three stations as 192.168.96.150 .160 .170
I should have used 192.168.96.1 as the Default Gateway, correct?
Jim
Iowa Quality Hay
: 1/17/2017 15:17
hanktherancher
: 1/17/2017 21:09
Iowa Quality Hay
: 1/18/2017 08:16
hanktherancher
: 1/18/2017 10:15
Iowa Quality Hay
: 1/18/2017 13:42
