Macon, IL | Folded planter and put in shed last year.
Got it out now and plug in control box and no lights. Opened the box and if I run a lead from ground on battery to ground test lead inside control box it will light up.
Have validated power from 7 pin and ground is registering on ohm-meter. Went to 20 pin plug-same.
Could it be that little relay inside control box? Other ideas? Other ways to test?
I have the tech manual-but for this scenario it just says "check planter wiring"-which I seem to have done and all appears fine. I know there is power to planter as if I let it set for a bit a couple solenoids on planter are getting warm. | |
