Posted 12/6/2016 09:08 (#5679514 - in reply to #5679464) Subject: RE: need a planter- brands? pull type or mounted?
ND
I'd say about 2 to 4 gal to run one pump an easy job for any JD tractor but only with closed center hydraulics, a 4020 can easily do the job or on smaller maxi planters with vac a 3020 also can do it or the newer 30 here like the 4230, 4430, series thro today but Deere has some 5000 & 6000 series that are priced cheaper to match competition with open center hyd that do not work.
