Carroll, OH | Clearance on the main drum would be an important consideration. Using a flat roller will not be as effective as the criminal records vanes, but may work if timing is right on. We put I&J rollers on a Harms frame last year for a customer. You could swap out the smooth drum for the crop roller drum if you wanted to.
(IMG_2398.JPG)
Attachments ---------------- IMG_2398.JPG (149KB - 33 downloads)
