| I would strongly recommend looking at 2560x1440 monitors, but you can go 4K as well, for myself I couldn't see the point, I use a benq 2730 and WOW they're impressive, supposed to be easier on the eyes as well. One thing you'll notice is with higher resolution you get a lot more real-estate from one display, everything does get smaller, but it can also be adjusted. I've gotten to like the benq displays, they're not overpriced, have nice adjustable stands and have the same panel as some of the high rollers, best bet would be if you could play around with the different resolutions in stores. | |
