SE SD | 2014 Deere S680 having problems with the large 1" hyd. hose running from the hyd block down to the hydro charge pump. Had a giant leak and noticed the big hose was loose. Tightened it up and added oil...combined for about 20 minutes and the same hose came loose again! Oil everywhere! I noticed that the hose pulses or jumps kind of bad even after adding oil. I assumed it was just air, but maybe it's a bigger issue? I'm stumped! Any ideas? Thanks | |
