roaming | Mnsidehill - 10/17/2016 21:04
Can you put in the actual moisture ? Mine is showing 6 percent too high on corn was about right on soybeans. I looked in wizard but couldn't figure it out.
You can put in the actual moisture of any load you want. Just select it as though you're going to use it for calibrations (either in the Wizard or in the Advanced procedure), then enter the actual moisture. It won't actually be used for calibration (so it won't have any effect on future or previous data) unless you turn it on as a calibration load.
Edited by torn 10/17/2016 22:27
