Posted 10/17/2016 11:24 (#5586169 - in reply to #5586153) Subject: RE: Creating field boudary in SMS with no data
Central KS
One way to do it would be to use the satellite imagery on SMS, find your field, and then create a new boundary layer. There should be a drop down menu on the upper portion of the map window to the far right where you can select "New Boundary Layer." Then you can draw the boundary needed and save it to your management tree.
