roaming | agronome - 9/24/2016 12:20
I have a Pro 700 which is leaving a 50 ft gap at the end of the field (where I put my header down) and a 50 ft overlap into the head land at the other end of the field. It seems to be a offset setting that I am not able to find in the display. Makes it a real problem when I go to print out my yield maps because all of the data is offset on the map.
Any suggestions would be greatly appreciated.
Toolbox > Yield, Flow Delay.
Skips at the beginning and overlap at the end means your current Flow Delay is too short. |
