Posted 8/30/2016 10:25 (#5499035 - in reply to #5498935) Subject: RE: If the bearing
East Central Iowa
I have the needle above and use it on bearings with rubber seals. You can grease and rotate until the bearing is full. Have done it on different machines. It can be messy but it works.
