northeast ohio | Learn what you want from AgLeader or Trimble and be prepared to buy when components are posted. As shown below, I am 100 percent positive you put together a used CFX750 or even a FMX(1000) with the basic FieldIQ switch(es) and a Seed Monitor Module for $2000 to $2500. If the module is in the cab you can power it without the full dual power to hitch cable.
As other have suggested, from this base you can add capabilities to clutch control, variable rate hydraulic drives and spray with just the addition of other modules, cable extensions and harness adapters. Most importantly the monitor can steer the tractor with an EZSteer at a reasonable cost (or EZPilot / NAV2)
The process - Trimble find the monitor you like on their website, review the manuals for function and download the appropriate cabling guide as a checklist. Note the example has yield monitoring unlock, cab kit is best offer and added high rate sensors. This gets the module a place to be mounted on the tractor at the hitch. Only part missing is 75529 which is an easy find used.
Edited by neo_ag 8/28/2016 07:37
(image.jpeg)
(image.jpeg)
(image.jpeg)
(image.jpeg)
(image.jpeg)
Attachments ---------------- image.jpeg (151KB - 112 downloads) image.jpeg (89KB - 108 downloads) image.jpeg (83KB - 111 downloads) image.jpeg (82KB - 121 downloads) image.jpeg (88KB - 98 downloads)
