Discovered cause of RTK problems, but can somebody explain the reason to me?
KSeaton
Posted 8/26/2016 09:26 (#5491058 - in reply to #5490669)
Subject: RE: Discovered cause of RTK problems, but can somebody explain the reason to me?
Can you turn off only the RTCM3 message types that you need, we have a bunch of hemisphere bases running and you can determine which RTCM3 message types you want them to send we are only sending 1004,1005,1008 & 1012 messages, if i add more message types the correction time increases due to more info coming into the reciever
here is a link to what each message type is
http://archive.is/lMZyF#selection-567.0-567.32
