roaming | catmendoo - 8/21/2016 09:19
Is it possible to merge data from 2 different brands of yield monitors. I currently farm with a neighbor. We each have our own separate operations. We have some equipment that is owned individually, and some that is owned jointly. We each have our own combines, but run together for greater efficiency. One is a JD with yield mapping, the other is a CIH without mapping abilities. I'm looking at updating my combine and would now have yield mapping. We use Apex to view the data from the JD. Is it possible to import data from a CIH Pro600/700 into Apex? Is it necessary to use another program? Any input is appreciated. Thanks.
Yes, you can merge the data from Deere and CIH yield monitors. However, you will not be able to do this with Apex, as Apex will not read the Case IH data file format.
If you use a program like AFS Mapping and Records or AgLeader SMS, you will be able to do it. |
