Kansas | My current house is currently 100% electric heat. I bought a wood boiler last year and still havent got it hooked up. I am trying to find someone without much luck in my area that will put the heat exchanger in my duct work. I also seen some kickspace heaters that look like vents in the floor that use the hot water to heat with. I was curious if I am crazy by thinking about putting one of these in each room and then getting a thermostat for each bedroom to run the kickspace heater and just keep the wood boiler seperate system from the current system. I am also thinking about building a oversized one car garage with a office above it this fall mainly for office space and storage. Thought about adding a propane boiler to that system so I could use wood, propane or electric (Propane and Wood would run on same system). Am I crazy with this idea? How many BTU would it take to heat a house with 1680 sq ft. | |
