Search Forums | Classifieds (132) | Skins | Language
Freightliner blower motor
SCIN Farmer
Posted 7/28/2016 21:42 (#5438072)
Subject: Freightliner blower motor
We have a 96 model freightliner..
We are having an issue with the fan.. It has 5 settings Off, 1,2,3,and 4... The only one that does not work is 4
I tested the switch, it is an 8 lead switch and when you put the switch on 4 everything is hot..
I went to the resistor pack, but I'm confused what I need voltages to be...
Amps look good, get to 8 amps on 3, and then go to nothing when you switch it to 4..
Where do I need to be looking?
