South Central Wisconsin | With the tractor on the ground, get a pry bar and pry between the kingpin and the MFWD joint, to see if there is any play. Next jack that side up just enough to get the tire off the ground and with a big bar, try and lift the tire. This checks the hub bearings. Go through and check tie rods as well.
If it feels tight, drain the oil from that hub and see how much metal sheen the oil has. Plug should be magnetic, so if it has metal fuzz, that's bad news. | |
