ne nebraska | Just put rear brake pads on my 1999 half ton chevy pickup. 4x4. Pulled old pads off, pushed plunger back with a c-clamp, reinstalled new pads, with new slides that came with the pads. Put caliper back on rotor(plenty of clearance at this time). Test drive and the right rear wheel gets very hot(brakes dragging). Take back apart, lube up caliper bolts(not sure this is what they are called), they are a little dry, lube me up, put back together, still dragging. Pull apart again, replace rubber brake line going to that whee, thinking it maybe has collapsed inside, bleed brakes, test drive, still drag, aside from replacing the caliper, I don't know where to go next. Anything I am missing? It did not do this before I changed pads, and did it immediatley after. Will get hot after 6-8 miles, and can tell rotor gets hot(discolored) so I know it isn't the park brake, that never gets used anyway.
Thanks. | |
