Posted 6/25/2016 16:59 (#5375358 - in reply to #5375306) Subject: RE: Jcb 541-70 won't start
Also I believe the fuse panel is to the right lower side of the steering colum. Check all the fuses in there . Also make sure you are getting 12 volts to the fuel shut off solenoid.
