| Hi,
I want to transmit a signal using ADL450 vantage pro radio from Pacific Crest and receive the same signal to be repeated using another ADL450 radio, but, I've reading technical documentation and I see to repeat a signal I need receive using an antenna designed for an specific frequency and then rebroadcast that signal using another antenna wich is configured to a different frequency. ADL450 has just one connection for one antenna and datasheet says that is possible work like repeater. So, my questions are:
how works that radio in repeater mode?
To repeat a signal i need more than one frequency?
Are there technical documentation about this?
I've been looking information related to this but can not find a clear data.
Thanks, regards.
