South Dakota | I think it is showing speed and work state down. I went into disk drill faults and found fault code 520215. This shows the code has occurred five times since last year when drill was new.
Wires going to the four control boxes or whatever they are on the shaft driven with hydr motor seem to be OK.
Air flow through all tubes is good and there is no binding on seed meters. Meter drive chains are OK.
Yes, it does show speed and work triangle points down.
Edited by mralleyoop 6/24/2016 13:04
