Posted 5/31/2016 23:32 (#5331082 - in reply to #5330755) Subject: RE: What do I look for when getting an Ipad.
I would recommend going to a store and play with the different sizes, you might find that a mini is just fine which also makes a great companion if you're out and about, where the bigger models can be bulky. Processor speed won't be an issue if you get the latest model. +1 for what Paul said on everything, Also recommend cellular capable you might need some day otherwise it helps resale value as well.
