Floyd County, Iowa | I've got EZ Guide 250, with EZ steer 500 T2 steering. I made several implement switches using mercury switches and micro switches.
I'm assuming you have EZ Guide 500. Should be easy enough to do. IIRC, I used 4&8 on the back of the EZ Guide 250 to hook the switches to, but 500 may be different.
Need to have the right pins for the connection to the lightbar.
I just used weatherpak connections at the other end of that harness and the implement harnesses so I can plug in the various implements.
Feeder house would be simple to do with microswitch.
