Nwmo | I have one setup on an agleader Integra running infurrow on the planter. I tied the boom signal wire into the aux on/off from the direct command module. It gives me 12v when any of the boom sections come on. I think for testing purposes you can install a jumper between the 2 wires on the boom sense cable and it will run all the time. Then you would have to setup your servo settings to "close the valve" when all sections are off, since there is no valve it would slow the pump until it shut off. Then it would have to ramp up to maintain the correct rate. Otherwise tie it into your boom valve signal wire, if you have more than one boom section it won't work very well. | |
