Southern Illinois | Got a 05 hagie sts10 the raven motor on top of the hydraulic valve that controls your pump speed went bad. Went to local sprayer store and got a replacement valve installed it and everything worked as should but was to wet to do anything. Tonight decided we wanted to sidedress before the next batch of rain comes in tommorrow evening and valve turns the pump on but can't get enough pressure to run. Do I need to replace the motor and the valve for them to function properly thanks | |
