Posted 5/23/2016 22:47 (#5317206 - in reply to #5316632) Subject: RE: Envizio Pro overlapping/leaving a gap
NE South Dakota Clark, SD
Offsetting the antenna under Offsets in the menu is the way to do it. Change the offset by half the distence you are off, then run up and back. Measure to see where you are and do it again. You may also have to reset the terrain comp in the smarttrax menu. If this was not calibrated, you will be off if you have any side slope on the ground.
